| Milltronics Discuss Milltronics Machines |
| ok i hook up exactly like in the blueprint red wire go to misc 11pin blue ground black to the relay tb1 spare relay common white to relay tb3 spare relay no contact and i hook up another wire wire fr tb7(is 24volt) to mics 13 pin wrote program 9025 M65 G4P.5 M75 M32 PROGRAM 9027 (DO NOT REMOVE) SET X7 CLR X7 change in the parameter m code 9025 to 71 9027 to 65 all done in the haas index pp1 to #1 relay pulsed for 1/4 second at the end pp2 #1 normally close. wrote short program M71 G1 X3 test it not woking. in the screen x input wait channel 0 for open when press cycle start M71 await channel change to 1 flashing 1 and 0 M FUCTION still on 0 however the index not rotate. can you explain how is the mics pin 11 talk to the index and how mics pin 13 work when hook up with the tb7(24 volt) thanx you |
| Misc 13 turns on the relay to activate the cycle start on the indexer. Misc 11 is the signal for the wait channel as long as it is grounded it will the cnc will wait. The indexer may need more time to start you can put a dwell between the set x7 and clr x7 make it SET X7 G4P1 CLR X7 this will make it wait 1 second. The indexer must have the parameter set so the indexer done signal is normaly closed |
| when i test M71 MISC pin 13 still on 0 didn't turn to 1 to turn on the relay. and mis pin11 keep flashing 1 and 0 constantly. in haas pp2 i set it to normally close. program 9025 and 9027 M code custom m71 m65 which program control for the wait channel msc 11 and mics 13 is there a way to test if the signal coming out those pin |
| Misc 11 is the wait channel. this needs to have a ground while it should be waiting. When it is grounded under the diag X in 7 should go to a 1. Then make a program that is M32 then some sort of axis move. The machine sould just sit until you remove the ground from misc. 11 |
| Thanks mholden, A guy was using this on his Cent 5: _ N1 PULSE1Y12 (OUTPUT WIRE FROM PLUG Y-OUT TO FIRE INDEXER) N2 G4 X.5 N3 IF PIN[1006]=0 GOTO 2 - This would work most of the time but he experienced intermittent lockups. His PULSEx parameter was set for 500 milliseconds. I'll tell him about M32. |
