- Need Help!- Centurion 4 "error 02 fault detected"
Running along, basic mill program. Stopped as usual, loaded another part, and got the error.
Have powered off and on several times.
It will home/grid out fine, jog around fine.
Will not run any programs
Unfortunately, the manual I got with the machine is jumbled, and after digging through it for 1/2 hour, I cant even find a mention of error codes.
Any help appreciated, this is holding production right now! Thanks!
Re: Centurion 4 "error 02 fault detected"
I did find a number of my Program Parameters match Machine Parameters. I have to guess they were accidentally entered at some point in there. But nothing has been touched on parameters in many months.
Here are the Cent4 error codes and a troubleshooting guide.
This list says an error 2 indicates a low lube alarm, add oil to the lube pump and see if the error goes away.
- You may not post replies
- You may not edit your posts
Forum Rules
