- HANG UP ON DRILL CYCLE NEED HELP
HI WE HAVE A MILLTRONICS CENT VI VERSION 6.635
RECENTLY ON DRILL CYCLE IT DRILL ONE HOLE GO TO THE NEXT HOLE AND IT
JUST STANDING THERE ON THE NEXT HOLE RAPID PLANE NO ERROR CODE
THE PROBLEM I DONT UNDERSTAND IT SOMETIME IT DRILL ALL 4 HOLES
MOST OF THE TIME IT DRILL 1 HOLE AND STANDING THERE NO FREEZE
IT HAPPEN ON IN DRILL CYCLE IN MILLING IT OK
Re: HANG UP ON DRILL CYCLE NEED HELP
are you using peck drill, feed in and rapid out, wood pecker drill? I had to take the Z axis backlash out of the control to make my RH 30 quit hanging up. As long as it was programmed in Milltronics Conversational, it worked OK but the same style of drill in Gibbs Cam caused it to lock up.
Good Luck
The Farmer
Hi Plast 474, This sounds like a "in position" error. The control is set up for :not running the nest line of cone" unless the following error falls below .005. This could be a drive error or a mechanical error. ( bad bearings or some other mechanical "binding" the does not allow the "true position" to be " feed" back to the control. look at the following error, when this happens. ( F1(prams) (f1 (setup) F1 (level) enter proto3 <enter> access level 3 escape back to the main menu. enter display, "error" this shows the "following error". if it is at .005 or above, we need to trouble shoot why it is hanging up. ( drive / motor/ mechanical etc.
Check and let us know.
- You may not post replies
- You may not edit your posts
Forum Rules
