Results 1 to 2 of 2
Thread: Mysterious Problem-Grinding Sound
    May 2010
    Im trying to work on a Milltronics RW12 VMC with Centurion 6 control and there is a nagging problem that Im not sure how to address.
    When the table travels in the X axis, only one direction, it makes a grinding/rumbling sound as it travels. Its enough to be heard throughout the shop and can be seen in the poor finish when that direction of the X axis is engaged in cutting.
    After many months of working with the machine I believe it can only be something in the servo/encoder/control. Perhaps its a parameter setting that Im unaware of. People have suggested bearings or ball screws but I absolutely cannot agree with them, it just doesn't sound like bearings/ball screws.
    When I switch between axes using handwheel I will sometimes get an additional .001" or so step in the axis Im switching from so I know something is wrong with what the machine is telling the servos to do.
    We all know what a machine sounds like when you are using handwheel and you have the increment set to .01" or greater. Sort of a knocking sound each time that step is taken. Well thats exactly what it sounds like in one direction on X the other direction is silent.
    A few months ago the CMOS battery died and many settings were lost. Im suspicious this problem started happening around this time which is good because it would indicate a setting needs changing.
    If anyone has any thoughts they'd be much appreciated.
    Jan 2005
    Wolfe88
    Can you do a video of the axes moving, we should be able to hear the noise it is making
    Mactec54
  1. Still have mysterious circles....
    By rewster in forum CamBam
    Last Post: 12-07-2010, 10:31 AM
  2. Z axis is mysterious
    By lilimike in forum Mach Software (ArtSoft software)
    Last Post: 09-11-2010, 09:37 AM
  3. LITTLE 'G' PROBLEM? Sound familiar
    By DomB in forum Haas Mills
    Last Post: 03-28-2007, 10:18 AM
  4. L297 l298 vibration sound problem
    By ez-cnc.com in forum Stepper Motors and Drives
    Last Post: 04-29-2006, 08:29 PM
  5. Rattling almost grinding sound with first tests of Y axis
    By phantomcow2 in forum General Electronics Discussion
    Last Post: 10-09-2005, 08:44 AM
