Results 1 to 3 of 3
Thread: Ml26 turret problem please help!
    Mar 2012
    u.s.
    I work at a shop with a milltronics ml26. The servo drive on the turret blew so out electrician purchases another one. When the ombré one was installed te turret would index but it would index farther than the actuall tool position. So he purchased an encoder for the turret, not when you go to home the turret or try to index it, the turret full rapid spins. And doesn't stop. Don't know how to fix it and our electrician is starting to loose his mind. The machine has been down for too long and any helo would be amazing! Oh and the turret is baruffaldi with live tooling.
    Registered Charlie Gary's Avatar
    May 2007
    Have you called Milltronics to ask for help? They're usually pretty good.
    Later,
    Charlie
    Jul 2010
    Brady 47, where did you get the drive from? Milltronics? some other source? Were the correct parameters loaded in the drive?
    Sportybob
  1. Chnc Turret Problem
    By unalpha in forum Hardinge Lathes
    Last Post: 03-08-2012, 03:17 PM
  2. HELP - Kia 15 turret problem
    By 3bmachine in forum Hyundai Kia machine
    Last Post: 09-01-2011, 11:30 AM
  3. FANUC 6T Turret Problem
    By kulbir in forum Fanuc
    Last Post: 04-14-2010, 03:33 AM
  4. Milltronics ML26
    By jhuddleston in forum Milltronics
    Last Post: 07-29-2008, 10:08 PM
  5. SL 10 turret problem
    By PBMW in forum Haas Mills
    Last Post: 08-15-2006, 09:51 PM
