Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 02-04-2012, 05:51 PM
poster is on a distinguished road
retrofitting an air blast in place of mist
I have an rh33 which has a mist coolant system wired in. Since i started using this thing i have never used the mist option but use "manual" (air gun) air blast daily. Can i remove the mister plumbing and run just direct air thru the solenoid thats already wired to the control and now have an "automatic" (fixed and controlled air blast) If not is it a big deal to install so i can use the control?
Old 02-04-2012, 08:34 PM
ZZZZ is on a distinguished road
If the mist system was installed at Milltronics, the solenoid valve is inside the mist unit and you wouldn't get enough air flow to be effective. You can break into the wiring for the mist unit and use it for a different solenoid.
I have installed quite a few of these:
Valve, Solenoid, 1/8 In - Solenoid Air Control Valves - Valves - 6JJ53 : Grainger Industrial Supply
You will need a needle valve like this:
Needle Valve, 1/4 In NPT, 600 psi, Brass - Pneumatic Flow Control And Needle Valves - Valves - 5TUL2 : Grainger Industrial Supply
(or something like them)
Plumb this with a few fittings and some nylon tubing and it works great.
(I have no connection with Graingers other than as a satisfied customer)
Old 02-06-2012, 10:36 AM
ok i was worried about the size of the solenoid. I just happen to have a grainger down the street so these part numbers will work out perfect. Also i wont have to break into the control to get to the leads, which was my main concern. I guess i will just have to verify with milltronics that the existing solenoid voltage is the same 24 volts? Also is 1/8 npt enough volume for the solenoid? I was thinking 1/4 but am not sure
Thanks for the info
Old 02-06-2012, 04:37 PM
That solenoid flows about 7 cfm, more than enough to make a mess if you don't throttle it back with the needle valve.
Take a look at this way to blow the coolant and chips off parts:
Lang Chip Removal Fans - BIG Kaiser
Several of my clients use these fans and they are quite satisfied with how well they work.
Old 02-06-2012, 05:54 PM
franchcnc is on a distinguished road
I have done about a dozens of these and a 7 cfm solenoid with a needle valve is a little weak. It is more money, but this is what I recommend.
I use these grainger parts.
24 vdc solenoid 4TR80
Connector for solenoid coil 4TR68
1/8" npt ball valve 1PZB2
There is a 1/8" npt tapped hole in the head casting to the right of the spindle to screw in the ball valve. You have to remove the head cover to access the to
the other side of the hole, but it conceals your air line.
The valve can be wired to the air blast output so you wouldn't have to disable your spraymist(if preferred). Depending on the age of the machine there should be terminal blocks for that. Check the machine wiring diagram.
Need Help!- Air Blast stevieboy HURCO 8 08-31-2011 03:37 PM
Need Help!- How to prepare a FADAL 3060 to transport form place to place Swykore CNC Machining Centers 0 08-08-2011 07:09 AM
Air Blast - Multus zooloader Okuma 9 10-11-2009 02:54 PM
Air blast MechanoMan General Metalwork Discussion 13 09-09-2009 01:20 AM
Air Blast jybute Haas Mills 6 12-15-2007 07:14 AM
