Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 01-06-2012, 09:49 AM
moldcore is on a distinguished road
Exclamation Spindle turns on unexpectedly!
I saw this twice yesterday and I’ve taken the machine off line until I find a solution. It’s an old (1995) Partner 1 enclosed bed mill with a C5 control.
Both times the spindle turned on when the operator hit the Z button in HDW mode. Not good.
Any suggestions on where to look (other than a new machine) would be appreciated.
Old 01-06-2012, 11:20 PM
ZZZZ is on a distinguished road
Do you have a remote keyboard plugged in? If so, try it again with the keyboard unplugged.
If you have a stuck ALT key, the F3 button in handwheel for the Z axis would give the same command as the CW button.
This problem could also be caused by a bad Keypad Encoder Board.
Here are the keyboard replacements for all the front panel buttons:
To Replace Front Panel Buttons
Alt + F1 Spindle Stop
Alt + F2 E-Stop
Alt + F3 Clockwise
Alt + F4 Feed Hold
Alt + F5 Counter-Clockwise
Alt + F6 Cycle Start
Alt + F7 Mist
Alt + F8 Tool Reset
Alt + F9 Flood
Alt + F10 Reset (may have to press the Reset button at the same time)
Feed Rate Over-ride Spindle Over-ride
Alt + A 0% Alt + 1 0%
Alt + S 10% Alt + 2 10%
Alt + D 20% Alt + 3 20%
Alt + F 30% Alt + 4 30%
Alt + G 40% Alt + 5 40%
Alt + H 50% Alt + 6 50%
Alt + J 60% Alt + 7 60%
Alt + K 70% Alt + 8 70%
Alt + Z 80% Alt + Q 80%
Alt + X 90% Alt + W 90%
Alt + C 100% Alt + E 100%
Alt + V 110% Alt + R 110%
Alt + B 120% Alt + T 120%
Alt + N 130% Alt + Y 130%
Alt + M 140% Alt + U 140%
Alt + < 150% Alt + I 150%
(Sorry, I can't get the formatting on the over-ride chart to work correctly)
Old 01-08-2012, 08:31 AM
ZZZZ, thanks but there is no way to connect a keyboard. Where is the keypad Encoder board located? And where can I find a replacement? The problem is intermittent. Maybe it’s time to dump this dog.
Old 01-08-2012, 11:50 PM
The Keypad Encoder Board is attached to the backside of the alpha-numeric keypad inside the front-panel. The connector for the external keyboard is on the Keypad Encoder Board.
Some machines have a jumper cable from the side of the front-panel to that connector.
Old 01-10-2012, 05:26 AM
Brian L is on a distinguished road
Here is a picture of the inside of my Centurion V control, the board in the left portion of the pictures is the keyboard encoder board, you can see the adapter and cable I used to bring the connection to the side of the cabinet.
My machine works just fine until I plug this cable in, evidently once plugged in it acts as an antenna and starts acting all sorts of weird, spindle turns on and off, machine moves at will, keys on the existing keyboard don't work at all, or take twenty hits to actually register. I panicked when I first hooked it up thinking the computer had gone haywire.... but disconnecting the wire has solved the issue... the factory version must have special shielding or something.... I haven't needed to use it since, so haven't delved into solving the problem.
CNC spindle motor turns on after computer boot oisyaot Benchtop Machines 9 11-20-2011 01:34 PM
4th axis turns to many turns cob Mastercam 6 02-16-2009 12:19 PM
What turns 4th axis 'on' in MCX? Donkey Hotey Mastercam 8 03-11-2008 07:37 PM
I'm done, but nothing turns pbarsalou DIY-CNC Router Table Machines 11 04-07-2007 11:15 PM
Okuma Vmc ,g80 Turns Spindle Off qmas99 G-Code Programing 7 05-20-2006 07:34 AM
