| Milltronics Discuss Milltronics Machines |
I have been working with Brian L. on his Milltronics Partner IV knee mill with Centurion V control. He is getting following error trips in ONE direction only on all 3 axis. I believe its the -direction on all 3. We are scratching our heads trying to figure out what is causing it. We pulled the timing belt of the X axis and tested the machine. (decoupled the ballscrew) following error seemed to be fine both directions. We manually turned the ballscrew and there was an ever so slight difference in resistance moving it back and forth. We don't think its enough to cause an issue. We could see a weak servo amp or encoder if it was on one axis but all 3? He has to run at 60 IPM or so, not to trip the machine. This machine is far more capable than that. Any ideas?? He has posted pictures in this forum. It has Fenner drives, I think they were 1270's (going from memory) Any help to get this resolved and the machine running as it is supposed would be greatly appreciated. If money needs to be invested, we want to know that it is in the right places. We HAVE followed the manual to set up and make sure the Servo Amps are adjusted properly. The computer has ACROLOC cards, though we aren't 100% certain which ones. Maybe one of you familiar with them might recognize them from Brian's photos. Thanks in advance for the help! Marty |
| If these are analogue input drives, do the test that I mentioned here, this will individually test the drive, motor and tach if it has one. http://www.cnczone.com/forums/fadal/...awayyyy-2.html Al.
http://www.cnczone.com/forums/milltr...ng_info-2.html Next time I am at Brian's I will try your procedure. Marty |
| Job to keep track with all these separate posts going on ![]() Al.
| Need Help!- X axis works fine but Y axis direction is erratic | swampbud1 | DIY-CNC Router Table Machines | 4 | 12-06-2010 05:28 PM |
| Need Help!- x axis will only move 1 direction | brent48 | Stepper Motors and Drives | 1 | 11-09-2010 11:25 AM |
| Problem- C axis direction | riverking | Daewoo/Doosan | 1 | 12-08-2009 06:38 PM |
| Need Help!- Error 414 Z axis error detect- servo alarm | andywids | Fanuc | 0 | 07-09-2009 10:33 AM |
| Need Help!- Error 414 Z-axis error detect servo alarm | andywids | General Metal Working Machines | 1 | 07-09-2009 09:56 AM |
