Originally Posted by
Brian L
Steve,
You need your tool offset call to have a corresponding offset number, not just H0, so your G43 line should look like this:
T05M06
S6000M03M08
G43 H05 D05
Now, you don't always have to have the offset and diameter numbers be the exact same as the tool number, there are cases where you might use two different offsets on the same tool, but.... in general, you always number the D and H values the same as the tool number.
Once that specific tool offset is active, then at the end of each tool, and at the end of the program, you put in a G40G49Z0M09 line.
