Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 12-04-2011, 03:38 PM
Brian L is on a distinguished road
Acroloop card tuning info?
I an having some following error issues with my '92 Partner 4 with Centurion V control. Following error runs exactly the same value plus and minus up to about 70 ipm, then when I step up to 80 ipm, it goes running off in only the minus feed directions, i.e. X minus, Y minus and Z minus... the plus directions all stay around the .050" level while the other direction climbs until it faults out the drive at .250".
We were just working with the balance and signal pots of the Fenner drives and I found out about some set up procedures for the cards, where you check ohms resistance and voltages at certain points, so now I will check all of that first.
That got me to wondering if there was the same sort of procedure for the Acroloop cards, so if anybody knows of a process where I can make sure they are set correctly, I'm all ears.....
Right now the machine is running, but I have to have my rapids set under about 70 ipm and such or the drives fault.
Old 12-04-2011, 07:22 PM
Al_The_Man's Avatar
Is this something that suddenly appeared? If so I would look to addressing the reason before retuning anything.
Are you saying that the drives go in to runaway condition at a certain feed rate?
If the drives have an option of mode, typically they would be set to Torque mode of operation.
Old 12-04-2011, 07:44 PM
Hi Al,
No, it's not running away, it's faulting the servos at anything over say 80ipm and shutting down the machine because of a following error fault. As for suddenly appearing, no not really, this machine had been sitting for at least 3 years, maybe longer in some guy's garage with no power, I got it, replaced the motherboard and made some modifications as we couldn't get the old motherboard to boot up.
The machine has had the following error issue since I powered it up.... I just went in and set my parameters for rapids at 60 ipm and keep my feed rates under that also. But, obviously something is out of whack, and I'd like to track it down and figure it out, so the machine can be operated as it should be. I am no electrical guru by any stretch, but have a friend who is helping with the electronics end, and with help from this board, I've gotten pretty far with the machine.... just wanted to know if there was some form of tuning needed on the acroloop cards.
My limited electrical knowledge indicates to me that because the following error has issue in the same direction for each axis, checks perfect below a feedrate of 60ipm or so on each, and then goes whacky above that point in each.... makes me think that there is some component that is failing or out of adjustment.... that is effecting each axis drive.... but then again, I'm pretty uneducated on electronics.... so I'm guessing....
Old 12-04-2011, 08:11 PM
Here is a video I shot yesterday, basically just the screen as we ran back and forth 5".... but it shows how the following error is stable in one direction, then goes climbing in the other.
Following error screen on Milltronics - YouTube
Old 12-04-2011, 10:26 PM
Al_The_Man's Avatar
Its been a while, I will see if I can dig out my Acroloop manuals tomorrow.
Old 12-05-2011, 12:28 AM
darrengladysz is on a distinguished road
Servo error
I may be wrong with this but in the config on acrocut or acromill there is a setting to turn off the machine if the following error exceeds a certain value. Can it be that your machine's servo's can not keep up and then acroloop turns off?
If I recall it is either f8 or f7 for settings to check this out.
Here is a link to the product literature:
http://www.parkermotion.com/manuals/Acroloop/ACR.htm
You can also download acrview (I don't know if your board supports this) to tune your servo, here is the link:
http://www.parkermotion.com/support_samples.htm
Let me know if this helps.
Darren
Old 12-05-2011, 10:43 AM
Yes, the machine shuts down if the following error hits .250", that's a parameter that can be set for each axis. As for why, I don't know, there seems to be no difference mechanically for any of the screws as to which direction I go, i.e. the same amount of force is required to turn for either direction, and there appear to be no tight spots, or anything like that. And the fact that they keep up in one direction with no issue seems to state that the servos can keep up. I was able, before I set the rapids to 60 ipm in the parameters, to rapid at 300 ipm in the positive directions only, so I don't suspect it's anything mechanical in nature.
Thanks for the links to the information, will have to decipher which might apply and see what I can figure out.
Old 12-05-2011, 11:06 AM
Al_The_Man's Avatar
Are you running a version of Acrocut or Acromill? or is this third party software?
In the Acroloop manuals there is a section Tuning the Servo PID loop and Acroloop has an internal scope display in the Diagnostic screen for watching the tuning results.
Also in the Acromill/Acrocut manual there is a flow chart of function for the different menu's, selection and F8 of the set/diag sets the parameters also.
It is also important to set the drives to the recommended mode, as a rule, drive are set to the Torque (current) mode of operation, you may want to see if the Fenner drives have this option.
If the problem is not mechanical and the drives/motors are sized right, then usually the symptom that produces following error is in the PID & drive tuning.
Old 12-06-2011, 10:24 AM
Al,
This is getting way over my head, but to answer what I can....
Acrocut or Acromill, I dunno, where/how would I find out? When the computer boots up I see "Acroloop XYZ" for a moment, and I checked my Main-Util-Info page and it shows "Centurion V CNc 1.29.09" and then below that after memory info, it states "Controller card v0206 0000" and below that I have:
X axis Acroloop v0208 0000 0100 0000
Y axis Acroloop v0208 0000 0200 0000
Z axis Acroloop v0208 0000 0000 0000
Beyond that info, I was able to take a card out, the X axis card, it has these numbers across it:
6-07-004-010 PC-ARCON-02
On the chip side of the card, I have stickers on some of the chips, one says
ACRO U9
C5B5
VER 2.08
Then stickers right on the board with
SN 158
REV A
92 13
I don't know if any of that answers any questions....
Old 12-06-2011, 10:34 AM
Al_The_Man's Avatar
The Acroloop XYZ at boot up appears to confirm that it is Acroloop s/w, but I don't recognize the screen in your Utube video?
Are you running under Windows or DOS?
If it is anything like the software I am familiar with, there should be on screen function keys that you can drill down to the Tuning menu?
I attended the Acroloop training class when the ACR8000 first came out, but that was many moons ago.
  #11   Ban this user!
Old 12-06-2011, 11:22 AM
Running under DOS, that screen was just the normal run screen with the display set for following error. If you want to see more screen shots, this is my photobucket folder for the mill, quite a few screen shots scattered throughout:
Milltronic pictures by dmogbrian - Photobucket
Old 12-06-2011, 02:13 PM
Al_The_Man's Avatar
I don't recognize any of those screens? I suspect that they use their own custom s/w.
I would expect a set up menu for the tuning, PID etc?
Is there any manuals on the system?
replacement acroloop card fcycles Milltronics 0 10-07-2011 02:00 AM
Wanted, one good Acroloop ACR2000 card joejared Want To Buy...Need help! 7 07-06-2008 08:39 AM
ACROLOOP OPS1000 kevin swan Controller & Computer Solutions 2 04-30-2008 05:50 PM
ACROLOOP Anyone? Al_The_Man General CAM Discussion 6 06-24-2006 09:26 AM
Acroloop 8000 MrWild General CNC (Mill and Lathe) Control Software (NC) 3 06-16-2006 06:38 PM
