Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 08-29-2011, 05:08 PM
bestrada11 is on a distinguished road
zaxis software limit
hello everyone that has helped with the problems w my partner 3. well i finally replaced the power supply to the servo cards and everything works except when i try to run one of the existing programs that was in the machine when i bought it i get a z axis software limit error #403 i believe what is the problem
Old 08-30-2011, 05:59 AM
sportybob is on a distinguished road
Z softlimits
The 403 Z soft limit over travel is just that, The program is try to set up a move out side the travel limits of the machine.
The Partner 3 has about 6" of Z quill travel, so if you tell it to move outside that travel you get errors, it knows "you cant go there".
1. look at at the G54 and G59 parameters and clear out any Z values. Then try again.
2. If you still get 403 error check the Z axis parameters for the Z travels ie: +.100 and -6.0 or such. check the parameter listing that should be in the manual for the travel limits on your particular machine.
3. Call Milltronics tech support. 952-442-1401
Sportybob
Zaxis repeatability forseral DIY-CNC Router Table Machines 22 03-27-2011 04:24 AM
Software Limit Issues pzzamakr1980 Tormach PCNC 3 08-25-2009 01:05 AM
Error 403 Z axis software limit overtravel designerpatrick Milltronics 6 02-12-2008 08:57 AM
Is it possible to have the software limit button turned on all the time? Darc Mach Software (ArtSoft software) 1 10-27-2005 07:16 AM
counterbalancing the Zaxis. Somle Mechanical Calculations/Engineering Design 5 06-28-2005 06:08 PM
