Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: Centurian 6 VM 16 power supply
    Aug 2011
    Question Centurian 6 VM 16 power supply
    Hi, my Cent 6 won't boot up/ come online. the power supply for the PC seems to have failed. I cannot find a replacement with the right connector for the motherboard. HELP!!
    Registered john_100's Avatar
    Mar 2007
    uk
    what are the connectors like ?
    it could be an old AT power supply ,if you can't get another
    you may be able to use a new ATX power supply by using your old connectors
    on the new supply
    John
    Attached Thumbnails Attached Thumbnails Centurian 6 VM 16 power supply-power_connector.jpg   Centurian 6 VM 16 power supply-pc_atx_psu_connector.jpg
    Aug 2011
    Smile many thanks
    that is what nobody could tell me. will try in the AM. Thanks for the help. Will keep you posted.
    Aug 2011
    cool, I will grab a new supply in tha
    e AM and give it a try. Thank YOU.
    Aug 2011
    The connectors are the inline 6 pinn ones like the first photo
    Feb 2008
    Quote Originally Posted by wezmfg View Post
    Can you show a wiring diagram on changing the connectors?
    I looked for an adapter to do this same thing.
    Atx power supplies are common but At supplies are harder to find now
    Thank you for your time
    Mar 2007
    uk
    Hi tpmx57
    do you have an old AT power supply you can take the two 6 pin connectors off?
    I'm not sure of US component suppliers but in the UK
    Maplin Electronics sell both the 20 pin ATX plug and sockets you could make your own adaptor
    ATX Motherboard Power Connectors : Motherboard Power Connectors : Maplin
    while looking on ebay for connectors i have found this :-
    ATX to AT power supply adaptor kit | eBay
    I'll add a diagram later
    John
    PS if your new ATX power supply has a 24 pin connector
    you can use a 20 pin plug if you make your own adaptor
    you don't need to connect to pins 11, 12, 23 and 24
    Attached Thumbnails Attached Thumbnails Centurian 6 VM 16 power supply-atx_converter.jpg
    Jul 2010
    C6 power supply
    If you have a machine that has a CRT you will need the "extra" 110VAC plug that AT type power supplies have. If you have an LCD display you could modify a ATX to work.
    You will also have to modify (add the wiring that goes to the NCB board. It is that 4 pin connector attached to ends of some of the wires comming out of the power supply.
    If you do not want all that messing around with the wiring call Milltronics parts 952-442-1418. Be up and running in 1/2 hour after the part arrives. UPS ground is 2 days to Detroit.
    Sportybob
    Aug 2011
    Unhappy
    Put in new power supply. Machine still does not come online. the LED's on the axis boards light up green but no video or control panel buttons
    Jul 2010
    C6 power supply
    did you check the voltages? +5, -5 +12, -12? what are they reading? when you installed the power supply, what type? At or ATX? did the 2 connectorers to the mother board get installed correctly? the black wires on each connector to the center? If all is OK, try conecting an external monitor dirctly from the VGA connector on the mother board and see if you get video.
    Sportybob
    Aug 2011
    The computer or machine appears to be waiting for a signal from somewhere to continue with start up procedure. The monitor is waiting for a video signal fron the computer. The green led on the floppy works also. It just appears to be in limbo.
    Aug 2011
    The voltages are correct. Does any one know a milltronics repairman in the Detroit area.
  • Page 1 of 2 12 LastLast
    1. Replies: 13
      Last Post: 09-16-2011, 05:59 PM
    2. How'd you supply your power supply?
      By cnczane in forum DIY CNC Router Table Machines
      Last Post: 08-28-2011, 06:13 AM
    3. controller power supply 115/230v OK for Australian power?
      By Momill in forum Australia, New Zealand Club house
      Last Post: 07-07-2011, 12:06 PM
    4. More power from switching power supply
      By R.thayer in forum General Electronics Discussion
      Last Post: 03-10-2007, 08:03 PM
    5. Power Supply from a computer power supply
      By jmytyk in forum General Electronics Discussion
      Last Post: 01-11-2006, 03:56 PM
