Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 05-25-2011, 03:48 PM
Joe Miranda is on a distinguished road
threading cycle help
I need to cut a 1/2-13 od thread and I am just not figuring this out. Can someone walk me through the steps. I have a Centurion V controller.
First of all I am not sure how to call out the tool since it asks for the feedrate at the tool change page - do I give it the lead at that time even though it asks for the lead again in the threading cycle page?
Secondly, when I tried to program the thread I wanted to take multiple cuts to get to depth so I tried using the multiple threading cycle and selected "crest" rather than "root and height". Was that correct or is there a way to use another threading function and still take multiple cuts for depth?
When I ran the verify it looked ok but when I hit "run" it would do the truning part of the program fine but when it got to the tool change line for the threading nothing happens - it just sits there.
Help!
Old 05-25-2011, 08:18 PM
ZZZZ is on a distinguished road
What is your software version? There were some changes in the software that can have an affect on the the answer to your question.
Old 05-26-2011, 01:30 PM
It looks like the version is T5.86. Does that sound right?
Old 05-31-2011, 06:09 AM
Still looking for some help here.
Old 06-05-2011, 02:20 PM
chipsinpan is on a distinguished road
do not put anything in the feed rate , just the tool RPM.
Do a rapid move in X & Z to the start location - x .520 , Z .1
put this event just before the multiple thread set up page .
Crest will be .5
start position , same as the preceeding position : X .520, Z .1
You use the start pos in X as a larger value than the crest because this is the dia it will rapid back to the start end .
lead will be 1/13 ( on my Cent 6 , metric threads must be converted to inch dimensions and expressed in thousandths per INCH )
( assuming you will set z zero as the point of the tool at the end of part )
don't forget to go to the tool table and set tool type .
set cut depth to about .015"
min cut :.001"
fin passes : 2
once it starts threading , the feedrate dial is disabled , but I think you can adjust RPM override to slow things down.
Let us know if this gets you closer . I can post the full setup page if you need .
Need Help!- Fanuc 6t threading cycle. jetfuelgenius General CNC (Mill and Lathe) Control Software (NC) 11 04-14-2011 12:50 PM
Threading cycle output Alrow Mastercam 1 04-11-2011 01:03 PM
CL2000 I.D Threading cycle cutshaw Mori lathes 4 04-24-2009 06:24 PM
G78 threading cycle on Fanuc 0i-TD Deco-Doctor G-Code Programing 3 01-06-2009 11:35 AM
Threading cycle chrisryn Parametric Programing 1 06-12-2008 03:04 PM
