Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-14-2011, 09:21 AM
muttley69 is on a distinguished road
Milltronics VM16 Cent V
Hi all
New to Milltronics but got a good deal on a machine so I bought it. I am having a problem with the x axis. It cuts small in comparison to Y, I tried adjusting the scale factor in the parameters but no change. I am running G-code programs so that may be why the parameters didn't change anything. The scale seems to be off about .0012 per inch. Any help would be appreciated.
Old 04-14-2011, 07:58 PM
ZZZZ is on a distinguished road
Is the error consistent for all moves? A 2 inch move gives a .0024 error, a 10 inch move gives a .012 error, a 20 inch move gives a .024 error, etc?
If so, it could be several things: a bad encoder, a bad Ball Screw comp table, the wrong PPU parameter, bad motion control, etc.
If not, positioning problems are frequently backlash problems: bad or loose thrust bearings, bad or loose ball screw or mounts, loose or worn drive belt or sheaves, etc.
Good luck finding the problem.
Old 05-03-2011, 01:15 AM
sportybob is on a distinguished road
Muttley 69
Any updated info from ZZZZ questions?
On your G code programes, are they posted from a CAD/CAM?
If the rate of change stays the same, .0012 accross the travel I would suspect a bad thrust bearing / backlash problem.
We neeed more info
questions? just ask
sportybob
Milltronics VM16 not homing. Ciaran Milltronics 17 02-21-2011 07:10 PM
Connecting Desk top to 1997 Milltronics VM16 SpeedMetal Milltronics 5 02-01-2008 03:56 PM
need help on milltronics cent 1 install index rotary table plast744 Milltronics 8 11-15-2007 11:16 AM
VM16 Info elecbeaver Milltronics 1 06-22-2007 07:34 PM
VM16 CNC shutting down elecbeaver Milltronics 2 05-21-2007 06:22 PM
