Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-19-2011, 08:20 PM
ihbuilder is on a distinguished road
cent IV wire diagrams
Any one have these ? I need some kind of diagram that shows all the connections at the MC1 contactor (Spindle motor ). It is for a Partner V
thanks Steve
Old 04-01-2011, 09:20 AM
Maybe I should be more specific ? I have a partner 5 w/ centurion 4 control needed to convert to single phase power . I bought a 10 Hp inverter and hitched it to the spindle motor (now running ) but like a dummy I disconnected the original motor contactor along with the E-stop wiring that goes through the spindle motor contactor . I can't remember the way it was wired do to time away from what I was doing . BTW , I did separate the control power from the spindle motor power . I had it homing before I disconnected al the spindle motor contactor wires . Only problem I had at that time was the Z axis would trip the control into over limit travel . Z Servo works by switching amps , so my thinking on the Z axis problem is worn out Z amp ? since X & Y have been replaced at one time clearly indicated by instal date on the X & Y amps and being glentec while Z is a servo dynamics . I basically need some kind of drawing to show the E-stop circuit . Any help would be greatly appreciated
Steve
PS I did contact Milltronics to no avail since they stopped supporting the control they must of just dumped all info on it in the dumpster , Which I can understand .
Old 04-07-2011, 07:56 PM
ZZZZ is on a distinguished road
I may be able to help, give me a couple of days to look for the diagrams I have.
Old 04-07-2011, 08:29 PM
OK thank you
Old 05-18-2011, 06:40 PM
just to let you all know I finally got this machine running , for how long ,IDK .
Old 06-07-2011, 01:18 PM
Ben Colby is on a distinguished road
The servo dynamics 1525 drive(s) are the original. Let me know if you still need the wiring diagrams.
Old 06-07-2011, 05:43 PM
Ben , I would need the contactor wire diagrams I took the knee and spindle 1's out and cant remember were all the wires belong I put a inverter in for the spindle motor . would be nice to get the rest of the wires back to were they belong , like the oil pump , seems I have it running constantly .
Steve
Old 06-07-2011, 06:35 PM
I have the original electro/mechanical manual. If you have a fax # I can take care of that for you or we can work out another method. I believe the oil pump is always on once the
servo's are energized.
Need Help!- Schematic Diagrams vanmcneil Machine Problems, Solutions , Wireless DNC, serial port 0 02-05-2010 06:08 AM
Schematic Diagrams/Block Diagrams of Fanuc Modules leor Fanuc 1 10-23-2009 10:14 PM
Need Help!- Looking for circuit diagrams guhl Fanuc 2 05-31-2008 01:12 AM
Wiring diagrams and CAD NC Cams General Electronics Discussion 1 02-23-2007 08:50 PM
cent 6 I/O HANSENTECH Milltronics 4 12-03-2006 04:27 PM
