Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-11-2011, 11:51 PM
chipsinpan is on a distinguished road
ML15 spindle orient command ?
Is there a spindle orient command for my ML15 lathe.?
It would speed things up a lot if I could get the chuck key hole to always stop at the same location .
Especially when the machine is in the low gear range , it is a bit of work to rotate the chuck by hand .
If the spindle can synchronize with the feed screw for tapping and external threading , it seems that a spindle orient should be a simple thing to program .
Old 03-12-2011, 10:06 PM
ZZZZ is on a distinguished road
Sorry, while the control does use the marker pulse on the spindle encoder to start the carriage moving for threading and tapping, those spindle invertors don't support orient positioning.
Old 03-16-2011, 09:24 PM
Farmers Machine is on a distinguished road
Smile
I have a 2001 ML 20, took it back to have the turret upgraded to Pragatti in 2006. and the spindle orient card was an option. At that time $ 1,200.00 dollars just as well been a Million, so I elected to just keep tugging on the chuck. Buying a new machine today, I would get every availabe option. With the age of our machines and a drive being a computer for motors, it might be better to change your drive out instead of trying to find a card. If you have 3 phase power, get the re-gen drive and it will use the high inertia energy of the spindle coming to a stop to back feed your supply power line instead of burning the power in the braking resistors and actually save money on power. havn't seen one that will re-gen on single phase like my shop.
Good Luck
The Farmer
Problem- Spindle Orient molassesbros OKK 0 09-11-2010 04:35 AM
Help with spindle orient SIERRAMACHINE Fadal 6 03-10-2009 03:36 PM
Need Help!- M19 Spindle Orient ragman Fanuc 2 04-01-2008 05:16 AM
Hurco MD1 spindle orient caleb505 HURCO 1 11-24-2007 07:14 PM
spindle orient nitemare Daewoo/Doosan 11 06-06-2007 08:38 AM
