Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-06-2011, 02:38 PM
dj_pigs is on a distinguished road
Angry Milltronics centurion V program?
Hi guys, I have a milltronics with a centurion V control, here is my problem, when I punch in a nice short program like just a drill hole, I have to press pause and resume and cycle start and flood make it go step by step, there is no error just stops after every command, also I noticed that a g54 command will make go bunkers, can any of you guys help please, the program will not run full auto. I am using bobcad/cam with fanuc o post processor. I also noticed the cancel star comes on...
Old 03-06-2011, 04:11 PM
Ezmoney is on a distinguished road
sounds like it is in single block mode.
Old 03-06-2011, 07:09 PM
ZZZZ is on a distinguished road
Could you include a copy of the code in a post?
It will help to see the actual commands the control is trying to process.
Old 03-07-2011, 08:46 AM
Ok, frist pic is from machine is running and program is hung up, second is pic of program, when I press the block button it turnes dark and I can't get the machine to move even with pause and resume...???? All three program stopping buttons are light in color when frist rebooting and running.
http://i1238.photobucket.com/albums/...s/IMG_2332.jpg
http://i1238.photobucket.com/albums/...s/IMG_2331.jpg
Old 03-07-2011, 01:12 PM
mholden is on a distinguished road
If you hit display error what is your following error wen the machine stops?
The problem maybe the axis is not in position.
Old 03-07-2011, 06:54 PM
Is the A axis connected and working?
If not, the axis may be drifting and the control is waiting for it to get back to position.
As Mark suggests, look at the following error display to check. You may also change the Following Error parameter to a 0 (zero) to force the control to not care if it drifts.
Old 03-07-2011, 07:50 PM
I do not follow, there is no error, timer is still running but machine will not move to next step till I press f9 pause then resume then it will go to next step, ???
Old 03-07-2011, 10:24 PM
Ok guys, I unpluged the A axis and now the machine is working, how do I fix this so it will work with a axis pluged in?
Old 03-10-2011, 07:56 AM
sportybob is on a distinguished road
PG
check the following error by going to display (F6) Error (F4) this will disply the drive "following" error rate. If the following error does not fall back to below .005 then the control will wait untill it does before continueing on with the next programmed move. This could just be a drive adjustment.
Call Miltronics tech support. they should help you with the procedure.
Old 03-10-2011, 08:01 AM
BIG THANKS GUYS, Everything working now...
Milltronics Centurion 5 450 error Help! Footie11 Milltronics 1 11-15-2010 03:04 PM
Newbie- milltronics partnerIV centurion V bullitt92 Milltronics 2 07-06-2010 04:51 PM
mastercam x3 to centurion 7 milltronics motor-vater Post Processor Files 2 05-30-2009 01:17 AM
Milltronics Centurion 4 amp capacitor ozturbo Milltronics 14 10-30-2008 01:06 PM
Milltronics Centurion Six CUTRITE Milltronics 10 10-13-2006 01:48 PM
