Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 02-03-2011, 01:01 PM
bill guinn is on a distinguished road
How do I load and execute a program off of floppy
I have a Centurion 7 controller. I can't seen to find how to load a file from floppy. I have a g-code program which I entered via notepad on a PC, wrote it to floppy now I need to read it off of the floppy, load it and execute it.
Can some one tell me what steps I need to take.
Also if I want to modify the program via editing it in the Centurion and write it back to floppy what is involved?
Thanks!
Old 02-03-2011, 09:04 PM
ZZZZ is on a distinguished road
Bill, I assume you have tried the Files - Load process without success.
Your problem is probably the file name.
The Notepad file you created will have a file name with a .txt file extension. The Milltronics default set-up is for the file to be named with letter P with 4 numbers for the conversational file and the letter O and 4 numbers for the G and M code file. Neither file can have any extension. When you create the conversational program 1234, the control creates the file P1234 and the file O1234.
When you run the file by Run – Old - 1234, you are running the O1234 file, the control supplies the O’s and P’s for you.
To get your notepad file to load, you will need to re-name the notepad file to O#### with no extension and it will load and run using that name.
OR
You can change a set-up parameter called Full DOS Filenames from NO to YES.
Then, you can create, edit, load, save, or run any file with DOS’s 8.3 filename using eight characters, a dot, and a three character extension, such as abcdefgh.123 or customer.001.
When you run the file, you will have to key in the full name or use the menu to select it. To run your conversational program 1234, you have to enter O1234.
Can't load program from floppy dresda Milltronics 16 07-23-2011 09:04 PM
How Do I Load a Program? ranchak Bridgeport and Hardinge Mills 2 09-04-2009 01:48 PM
Need Help!- Can not load a program via MDI steelhead9 Fanuc 4 01-22-2009 10:31 AM
How to execute a cnc program without logging to the execute mode of the graphical use sabreen General CNC (Mill and Lathe) Control Software (NC) 0 02-04-2008 05:29 AM
How do you make Bridgeport execute program? Bill Gillen Bridgeport and Hardinge Mills 10 06-14-2005 08:26 AM
