Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 01-23-2011, 12:05 PM
pbarry is on a distinguished road
executing a program with sub
I have just been hired by a company to program and operate a milltronis mill with a centurion 5 controller.I do not have a book for it.I have written a easy loop program called o100 and it calls o200.
m98 po200 l10
this tells me program 200 does not exist.Any ideas what I am doing wrong?
Which drive do i put the files in to run them. Any help would be appreciated.
Old 01-23-2011, 01:56 PM
franchcnc is on a distinguished road
Sub call
If the file names are o0100 and o0200 the call statement M98 P200 L10 should work. Omit the "o" from the M98 line.
Old 01-23-2011, 04:08 PM
thanks alot i will try it tommorow.
Old 01-23-2011, 04:28 PM
Do I have to run the program out of the parts directory
Old 01-27-2011, 08:25 PM
AMCjeepCJ's Avatar
AMCjeepCJ is on a distinguished road
If you want a quick way to check how to write the code, use the conversational programming boxes, write the a partial program like a "call" for instance and then open up that program in the text programming area.
If this is confusing what I am trying to say, I will be back at the shop next week and I'll tell you the F key sequence to do this. It will basically write you sample code to show you the format you need to use when typing G code.
Gimpy aka 313 (three thirteen)
The early bird may get the worm, but the second mouse gets the cheese.
Outputting Common variable values into a program (with automated program number) yaji63 Fanuc 0 12-27-2010 02:55 AM
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
Newbie- Whhat would be the best process for executing knife designs? pesky_human General Metalwork Discussion 14 11-12-2008 09:52 PM
Anyone got any basic examples of a program using a subroutine/program? Darc CamSoft Products 11 10-08-2005 11:45 PM
