Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 11-14-2010, 12:07 PM
Footie11 is on a distinguished road
Milltronics Centurion 5 450 error Help!
Newbie here, I have a milltronices Centurion 5 retrofit on a Supermax YCM-40.
I'm trying to get the machine to home but I immediately get a 450 e-stop error. Check each limit switch and they are fine. I've also home (here) then tried to Jog each axis but nothing moved, then excess error! Tried changing the home sequence but nothing. I've gotten the table to move here an there trying different combinations but could never get anything consistent. Just looking for help on what to check next!
Old 11-15-2010, 03:04 PM
moldcore is on a distinguished road
It’s normal when you first turn the machine on to get the 450 error. Hitting the green reset button first thing should clear it if the table or head is clear of the overtravel limit switches. Try holding down the green reset button and use the handwheel to move the table clear of the switch. I believe the 450 error could also mean that one of the drives is being over worked by a bad servo drive or bind in the lead screw or linier guides. Also check air supply and lube levels. Do a search of this forum for more info.
Need Help!- Milltronics Partner 4 w/Centurion 5 -> Error 450 and keyboard problems!! varga Milltronics 37 01-27-2011 01:10 PM
Newbie- milltronics partnerIV centurion V bullitt92 Milltronics 2 07-06-2010 04:51 PM
Milltronics 3 axis Centurion 6 Chizel GibbsCAM 0 05-04-2010 11:25 AM
mastercam x3 to centurion 7 milltronics motor-vater Post Processor Files 2 05-30-2009 01:17 AM
Milltronics Centurion Six CUTRITE Milltronics 10 10-13-2006 01:48 PM
