Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 10-16-2010, 10:49 PM
borne2fly is on a distinguished road
Can't get the RS232 working
Milltronics Cent 1 controller. I've set all the parameters on the controller and the Dell XP laptop ..... baud=1200 baud, databits=7, parity=even, stopbits=2 .... got a null modem DB9 to DB25.
Can't seem to transfer files, either sending or receiving. The Cent 1 keeps saying something about a parity bit conflict even though the parity is set correctly according to the manual.
Using the Hyperterminal on the laptop, I can sometimes see data on the laptop when I send from the Cent 1 to the laptop when I do the following .... In the hyperterminal window I select Transfer. It then asks for the name of the folder to place the data into. If I DON'T do this and hit the start button on the Cent 1, I will see the correct data going by on the laptop, but only a line at a time, so that when it's done I only see the last line. If I DO enter a receiving folder name then I get a parity error message from the Cent 1 and no data transfer at all. It would appear that the data is getting to the laptop but the laptop is unable to capture it. The file in question works properly on the mill.
I have tried various baud rates and receiving protocols (something the hyperterminal asks for, don't know which protocol is best). I have tried selecting Xon/Xoff, hardware, and "none" for the handshake. What's left to try? Totally baffled. Hopefully it's not some broken hardware.
Old 10-17-2010, 12:26 AM
I get "Error 901 .... the system sending data may not have the same parity as the CNC". However, if I tell it to transfer the file as a text file it makes the jump in either direction, but the file contents are littered with extra characters and the format is lost.
Old 10-17-2010, 09:51 AM
Al_The_Man's Avatar
Hyperterminal is pain, try Cadem Lite, free Cadem CNC programming, CADCAM, Education, Training, Cycle time reduction, Conversational CAD/CAM, MES, OEE, Lean, TPM, DNC, Free DNC
Old 10-17-2010, 11:05 PM
Hey .... I got it running! Eureka! But you're right .... hyperterminal is a clumsy damn thing. And the Milltronics manual forgets to mention little details like "make sure you transfer the files as text files, 'cause the other formats won't work". At least this verifies that the RS232 cable has the pins "flipped" (the correct null modem), and the RS232 communication path is working. Now it's on to DNC. Hopefully it will go a bit easier.
I'll definitely take a look at Cadem Lite. Thanks!
Need Help!- WITH RS232 bruiserba Okuma 2 11-06-2009 12:49 PM
USB to RS232 FUN4ME Fadal 7 02-14-2009 03:25 AM
Hurco KM1 RS232 to USB OR RS232 to PCMCIA solution? modernprecision Bridgeport and Hardinge Mills 1 09-11-2008 01:15 PM
Need Help!- rs232 littlerobb Haas Mills 8 02-28-2008 02:49 PM
RS232 Help Jerrytool Daewoo/Doosan 9 03-15-2007 05:51 PM
