| Milltronics Discuss Milltronics Machines |
| I have the parameters on paper and on my pc. It's very easy. Email at benjamincolby@centurytel.net and I can help you out. Your battery for holding the parameters in memory is found at McMaster-Carr part # 6951K12 3.6volt "D" size. |
| The ERROR 4 is telling you that your servo drives are not activated, ie. turned on. I'm assuming you solved your parameter(s) problem? So you turn on the machine and it wants to GRID (go home on all 3 axis). You must depress the RESET button to turn on the servos. Once the servos are on you can grid the machine. If the servos are not on you will get an ERROR 4, whenever you try axis movement of any kind, ie. GRID, MDI, JOG, Handwheel. If the servos don't turn on, you have another problem which could be a number of things, and I'll need more info. Ben |
| Partner IV with Centurion IV controller - Operational | SpeedMetal | Milltronics | 12 | 02-01-2011 03:29 PM |
| Newbie- Partner IV w/Centurion V Problems | KurtsKustom | Milltronics | 19 | 05-09-2008 07:53 PM |
| Partner 1, Centurion 5 upgrade problem | lotsa luck | Milltronics | 12 | 12-20-2007 09:11 PM |
| partner 0-5 centurion 5(homing problem) | irtaza | Milltronics | 17 | 08-02-2007 10:16 PM |
| Partner centurion 1 control | jas6142 | Milltronics | 1 | 12-04-2006 10:49 AM |
