Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 08-01-2010, 12:39 PM
chipsinpan is on a distinguished road
V belts for ML15
Just took delivery of my used 2000 ML15 and noticed the drive belts are pretty shredded . These are the VEE belts from the drive motor to the head gearbox .
The manual does not tell the part # . It just says "belt "
I know this is an imported lathe bed , so it's probably a metric belt .
The only numbers on the belt are : 1783
It measures approx 75" in length and is about .540" wide .
Where do I get these belts ? I need 3 of them .
This probably explains why the PO needed a bigger machine with more power .
It was only running 2 of 3 belts and one of those had flat spots !
Old 08-01-2010, 06:43 PM
Farmers Machine is on a distinguished road
I have an 01 ML 20 that uses the A section V belt A-73, you can get them at industrial supply house or at a large automotive store, just ask for a matched set when installing 3 new ones. Take the old ones with you, they can measure them in the store with a belt measure tool and fix you right up.
Good Luck
The Farmer
Old 08-02-2010, 05:35 PM
Thanks Farmer
I went to the auto store & they got me 3 belts within 4 hours .
I insisted they were 75" but they measured them at 74 " .
So now I have 3 belts that are too short . ( motor adjuster out of threads , all the way up )
No big deal , they will get me the right ones tomorrow .
So the correct belt for a ML15 is : 1/2 X 75" which I think is an A74
Why could'nt they just put the size in the book ?
Old 08-06-2010, 04:47 PM
jpawelk is on a distinguished road
Originally Posted by chipsinpan View Post
Thanks Farmer
Milltronics would have this information available for future questions/inquiries. The parts department can be contacted @ 952.442.1430.
Proper way to lift an ML15 lathe chipsinpan Milltronics 7 06-29-2010 08:15 PM
Need Help!- belts fjmartineze Bridgeport and Hardinge Mills 0 10-14-2009 11:59 AM
240 msb sub belts BAD DOG Daewoo/Doosan 4 08-08-2009 04:53 PM
ML15 x axis problems Hickory Milltronics 6 04-25-2009 04:57 PM
L Belts BigBee Want To Buy...Need help! 0 03-18-2008 11:43 AM
