Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 06-21-2010, 05:21 AM
Chizel is on a distinguished road
Posting Gibbs Cam to Milltronics
I have a Milltronics Partner I E with a Centurion V control, and have serveral posts for Gibbs cam. I have Posts for Milltronics and Fanuc. I have been unable to get the machine to read a program from a disc. Is there a certain format that I'm not doing correctly? Or maybe the post isn't the correct one? Does anyone know if you have to have a % at the begining and the end when posting on a Milltronics? Any help would be greatly appreciated. Thanks,
Chizel
Old 06-21-2010, 07:53 AM
trevj1 is on a distinguished road
You need two things to make it work.
The file name format to be recognized by the Milltronics machine must be correct, and the file extension must be as well.
Name. 1 letter, either an O or a P, followed by 4 digits, so P8888, (for a conversational program, IIRC) or O8888 (for a regular file)
Extension. Gibbs wants to default to a file extension. I've dug around a bit, have not found the option that will set it's default to what I need, so I just Right-click on the file and rename it to whatever I am dealing with at the time, and remove the file extension, click yes, when it pops up with the warning, and then transfer the file to the floppy. You need to set your computer so that file etensions are visible to rename them like this.
If you are doing those things already, pretty much need a bunch more info to tell what may be the problem.
I've had to deal with crappy floppy disks, as well as a crapped out drive on my computer, on the Partner 4/w. Cent V on it at work.
Worth a try.
Cheers
Trev
Old 06-21-2010, 04:03 PM
jpawelk is on a distinguished road
Worth a try.
Cheers
Trev
All of these things you mention are true, however can be all avoided by simply pressing the letter D on the keypad while in a program menu list. This toggles the parameter "FULL DOS FILE NAMES". With this MISC parameter set to YES, the file name can be anything with any extension you would like to use.
Milltronics rw 12 lager1978 Milltronics 2 10-28-2009 11:47 PM
Gibbs Post needed for Milltronics w/ Centurion Vii ABCOTIM Post Processor Files 0 10-08-2008 10:13 AM
MILLTRONICS ML-15/40- Anybody own one? gunsmither Milltronics 3 10-22-2007 11:36 PM
Buy new Milltronics or what else??? schrupphobel72 Milltronics 35 07-17-2007 07:17 AM
Milltronics AMCjeepCJ Suggestions for the CNCzone.com site. 2 12-21-2005 12:48 PM
