Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 06-10-2010, 06:24 AM
mdc mdc is offline
mdc is on a distinguished road
rotation on centurion 5
How do we make rotation work on a centurion 5?
mdc
Old 06-11-2010, 11:30 AM
msomerville is on a distinguished road
Very easy with the conversational side of the control. Go to the special menu then choose rotate and input the values. Toggle the rotation off when done.
Old 06-11-2010, 11:36 AM
mdc mdc is offline
Thanks. How is the program structured for a 360 deg. rotation? We are trying to cut a cone shape.
Old 06-13-2010, 11:27 PM
*Registered User*
LJ48 is on a distinguished road
Hi
If you are talking about a cone shape, i would call that a 3d shape. I am sure rotation is used to rotate a shape or Bolt pattern. Example say you programmed a slot from "0" to the 3 O'clock position. With rotation you could rotate it 180 degrees and it would go from "0" to the 9 O'clock position.
Old 06-14-2010, 10:29 PM
ZZZZ is on a distinguished road
Take a look at the Taper Wall option found on the End Mill Cycle event (on earlier software versions). Just program a Start Mill Cycle, a 360 degree arc, and an End Mill Cycle with the Taper Wall option turned on. You can play with the numbers to get exactly the cone segiment you need.
Old 06-15-2010, 06:11 AM
mdc mdc is offline
Thanks to all, we will give it a try.
Centurion 7 help absolut Mastercam 0 05-17-2010 11:21 AM
rotation marcT G-Code Programing 4 01-30-2008 12:12 AM
G&L rotation abigg G-Code Programing 0 10-02-2007 07:26 AM
Centurion 5 vs. Centurion 6 and validation codes Turbo VW Milltronics 2 02-11-2007 02:35 PM
I'm Considering a Centurion 1 TZ250 Milltronics 9 09-07-2006 02:30 PM
