Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 05-15-2010, 12:12 AM
larry53 is on a distinguished road
conversational software
We have a older Miltronic mill that has conversationsal software. I was programming movements and had a problem I do not understand. The machine is at work so I will try to explain the problem from memory.
I was doing line movements milling a square out. I punch in the x and y starting positons and the x and y ending positions. When I came to the point that I should have ended up in the same position the table went further than I expected. A example would be the first movement was, x= + .850, y=-1.400
tool on right side. The last program I type in the same positon but the table moved passed the +.850 positon on the x axis. I had to type in + 1.00 to keep from running in a shoulder. Through out the programming I put tool on right side. I thought it would end up in the same positon I started at. I thought because the tool on right side that the outside of the tool would endup at the same positon as started. I know I might not have put in enough information to help someone understand my problem, but I thought I would give it a shot on someone having the same problem.
Old 05-15-2010, 07:23 AM
christinandavid's Avatar
christinandavid is on a distinguished road
Does the control/program use cutter compensation? If so the solution could just be a case of a putting in a departure move away from the contour, simultaneously cancelling cutter compensation.
Some controls can cancel cutter compensation whilst retracting in Z, some will need that departure movement. It is also easier to approach/depart somewhere along the edge of the square rather than the corner, that way if the cutter overruns it won't matter too much.
DP
Old 05-15-2010, 09:22 AM
It allows a input asking which side the cutter is on and also ask for the size of the cutter. The machine is only two axes with cnc control. I think when I input thet x position and moving clockwise it puts the cutter on the right side as inputed. but when it goess to the next position x would still be on the right side and y would be on the right side. But the next movement would still have x on the right side but y could be on the side not wanted because it must go to the dimension placed in which would put the full cutter in that positon and not the edge of the cutter. Then the next movement would put x at the imput dimension and y on the right side. where as x could travel again the whole cutter diameter instead of the edge of the cutter. I am milling out a pocket put doing this with line movement instead of using the software on the machine that is just for pockets. The reason for this is that if I just mill out a pocket the machine will stop and ask for a z axis check. I am trying to mill without stopping until I can machine out 2 pocket each on the side of a step that has radius's on the corners. I want to keep the same depth without moving the z axes. This may not make any sense the way I am explaining the problem.
DPRO Conversational Software Joey G-Code Programing 7 08-01-2010 05:15 AM
Hurco conversational vs. Milltronics conversational dfpen HURCO 10 12-29-2008 03:35 PM
New Conversational Programming Software BlueChip Product Announcements & Manufacturer News 1 01-25-2006 01:35 PM
conversational software GENMACH General CNC (Mill and Lathe) Control Software (NC) 5 01-01-2006 06:06 PM
Conversational CNC Software BlueChip Product Announcements & Manufacturer News 0 02-07-2005 11:43 AM
