They y & z axis rubber way cover on my machine has a pretty good size tear in it. Does anyone know of a good way to repair it or should it just be replaced ?
Thanks for the help.
I have done that repair a couple of times. It is not that hard. I purchased the rubber from MSC. I cant remember exactly what I bought (couple of years ago). But you need the better grade that is oil resistant. Basically you remove the old rubber and cut the new to same dimensions and you will need Contact Cement for attaching to the rolling mechanism.
Hope that helps
Scott
