Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-01-2010, 08:31 AM
multiplex is on a distinguished road
Partner V - Spindle Issue / Repair
so an idiot here at work managed to practically destroy my machine
he decided it would be a good idea to wipe the spindle off with a rag while it was turning. the rag managed to get sucked up into the cartridge
I was able to get most of the rag out by turning the spindle by hand back and forth. eventually i was able to run the spindle, but there was some serious heat being generated.
due to this, i figured we needed to disassemble the cartridge and clean everything out. I began the task, and ask the operator to keep going (as punishment)
i return 10 minutes later to find he had a 6' pipe on the wrench, trying to get it apart. Now everything is jammed up more than ever
the spindle is rotating with the end cap nut on the cartridge. I'm at a loss as to what to do, without further damage
any ideas?
Old 04-27-2010, 11:10 PM
PrecisionSpindl is on a distinguished road
Spindle Repair
If you are still having spindle problems, send the cartidge to a spindle repair facility -
Contact -
Precision Spindle & Accessories Inc.
www.precisionspindleinc.com tel. 519 671 3911
haviland@precisionspindleinc.com fax. 519 652 5994
Spindle repair smittys800 Fadal 18 02-27-2010 01:42 PM
Need Help!- CNC spindle repair Mikecarter Machine Problems, Solutions , Wireless DNC, serial port 3 02-15-2009 07:55 PM
BP 760/22 Spindle Repair KTD1 Bridgeport and Hardinge Mills 1 03-29-2008 02:35 PM
Partner 4 Z axis issue ozturbo Milltronics 3 03-21-2008 10:29 PM
Mill spindle repair? kong General Metal Working Machines 6 04-02-2005 12:01 PM
