Where can I find a new drawbar?
Results 1 to 8 of 8
Thread: Where can I find a new drawbar?
    Member SWATH's Avatar
    Aug 2010
    Default Where can I find a new drawbar?
    The threads have finally stripped on mine and now I can't hold some of my tools.
    warmachinellc.com
    Jul 2006
    Default Re: Where can I find a new drawbar?
    I make my own. I'll post some info later tonight
    pete
    Aug 2010
    Quote Originally Posted by slowtwitch View Post
    That's what I figured. Do you make from scratch and from what material?
    warmachinellc.com
    Jul 2006
    I buy grade 8 bolts (7/16x20) from Mcmaster (part # 91257A487). Look at the pdf, (don't mind the bad pdf drawing, I'm a rank beginner at this cad stuff), but it will give you an idea of how I made mine. The hex is 5/8" 4140 , also from Mcmaster.
    The intermediate part is made from some round stock I have laying around. I turned it to act as a guide for the hole at the top of the spindle nd to help in releasing the collets.
    In my situation, using my power drawbar thing, I hardened the Hex portion and use two roll pins to hold it in place (the pdf does not show the holes on the end of the bolt) . The harding really helps with using a power drawbar.
    All the sizes are approximate (I'm at work and I just winged this from the top of my head
    Attached Thumbnails Attached Thumbnails Where can I find a new drawbar?-mikini-drawbar-pdf
    pete
    Aug 2010
    Thanks Pete,
    I ended up having a friend make pretty much an identical copy on his lathe. Once I got it I realized it needed a minor diameter tweak and rather than send it back and since I don't have a lathe I did it on the machine using it as a vertical lathe.
    Where can I find a new drawbar?-img_20150729_214240-jpg
    warmachinellc.com
    Aug 2010
    I machined the hex today and opted for a 3/4" drive to match my vise, I then heat treated it with a MAPP gas torch and used motor oil. I'm now tempering it at 350F for an hour. This one is made from 1215 steel but next time I'll use 4140.
    Where can I find a new drawbar?-20150730_152740-jpg
    Where can I find a new drawbar?-20150730_152801-jpg
    Where can I find a new drawbar?-20150730_152902-jpg
    Where can I find a new drawbar?-20150730_153456-jpg
    Where can I find a new drawbar?-20150730_153544-jpg
    Where can I find a new drawbar?-20150730_153651-jpg
    Where can I find a new drawbar?-20150730_153826-jpg
    Where can I find a new drawbar?-20150730_153833-jpg
    Where can I find a new drawbar?-20150730_153854-jpg
    warmachinellc.com
  7. #7
    Jul 2006
    Nice job, Jim !!!!
    pete
  8. #8
    Member bill south's Avatar
    Apr 2005
    That turned out nice!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
