- Drive Belt Spindle Pulley Removal
So, has anyone removed the drive belt pulley on the top of the 16010L spindle assembly? I have the spindle assembly out of the mill, but am having trouble removing the pulley. Have tried heat from a propane torch, jaw puller, no luck. There was a strange threaded collar on top of the pulley which I have removed. I can't understand the purpose of that collar unless it was used with a custom Mikini tool to pull the pulley. Ideas?
Thanks,
Scott
- You may not post replies
- You may not edit your posts
Forum Rules
