- Choice of a laser machine
Hello every body from Switzerland!!!
I'm a industrial designer and I want manufacture a self-design product in very hard plywood (aviatic plywood) in 3 millimeters.
The pieces are now milling with a cnc that I made 5 years ago, but we want now buy a laser cutter for don't make the hand finition in the wood and for be to speed.
The hight compagnies has Epilog, Trotec are very too expensive.
I have make a research and selected differents compagnies. I want just know if you have experience with :
- Jiangsu Keyland Laser technology Co.
- Iehk
- Jinan JinQuang Laser CNC Equipment CO
- Jinan G.Weike Science & Technology Ltd (maybe the best?)
We want a cut surface of 600x900, but the door of the workshop is exactly 1 meter. Compagnies submit to cut the shell in 2 parts for go through the doors. Have you experience with this modification? The work is proper?
I'm precison mechanical and designer, not engineer and I don't have the knowledge for repare electrical or informatics problems. I want just be sure that the installation and the using are simple and friendy.
Many thanks for your futures answers!
Gazouille
Gold Member
Did you notice which forum you posted into and which vendor it addresses?
This is for the Mikini CNC mill - you will probably have better luck getting your questions answered in a laser-specific forum.
Mike
- You may not post replies
- You may not edit your posts
Forum Rules
