Uploading some videos of each step of the operation here:
Wagoneer Parts album | mcphill | Fotki.com, photo and video sharing made easy.
This was my first part. It has quite a few issues... 3 of the next 5 I made look great. One came out of the vise as I was machining and got banged up (but still usable), and one has a thin "foot", must have had a chip under it in the vise. Also usable, but not perfect... Will post more of those parts later. Off to a Beer Bash!
LinkBack URL
About LinkBacks
I did the center drilling on each part (which was no where near deep enough, but I was too lazy to go back and make them deeper), then put each part back in to the vise (one at a time) to drill through each, then back in a third time to do the third drill size. Totally NOT the "right" way to do things, but it worked for what I needed. If I end up making these parts "for real", I will set up a fixture to machine 4-5 parts at a time with known proper spacing, and not make them one at a time (or I will hire it out to a real shop!). I do plan to use the machines for prototypes prior to sending the "real work" out for higher volumes of things I design. As for the drill "scraping" each time it enters and exits the hole, you can certainly see in the video that the drill bit has a ton of runout too - it was one of a cheap set from Harbor Freight - something like $15 for a full number set, so I can't complain. I couldn't use flood coolant as the chuck I have is too long to let my coolant lines reach down and around. I need to extend the lines some but I keep forgetting to buy some more of the segmented tubing....
