Hello, I'm in the final stages of re-wiring my Mikini mill. The reason for the re-wire is that this was a used machine and had some issues with loose connections and such. So i decided to redo the whole thing
Anyway, I have everything hooked back up, except for the drivers. The Mikini drivers use a 16 pin connector and the cable is a 10 pin connector. Could someone check which pins the cable is attached to. I assumed they were keyed, but, they are not. A picture would be nice
thanks
pete
LinkBack URL
About LinkBacks
