Results 1 to 3 of 3
Thread: Integrating a Tormach ATC...
    Feb 2009
    Who wants to help make it reality?
    Installing the Tormach ATC « Milling Around
    http://www.tormach.com/document_libr...S32279_ATC.pdf
    Looks doable to me, need to make a bracket to allow proper positioning on the Mikini, need the right pinouts on the machine side (likely a second parallel port or a SmoothStepper), then "hopefully" can integrate the screen/code from the Tormach MACH3 in to standard MACH3 (this may prove to be the hardest part if the code is "locked down" in some way..).
    Aug 2010
    I was wondering the same thing. Of course you would also need an automatic drawbar.
    Feb 2009
    Of course
    Probably won't start on this for a while, as I don't even do toolchanges at the moment more than once every couple weeks, but once I get to making some parts on a regular basis I can see this being VERY desirable...
    Gotta get some of these projects done!
  1. Cad Cam for the tormach?
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 07-21-2010, 12:18 PM
  2. Need Help!- integrating fanuc ac drive w/mach 3
    By texasfiddler in forum Mach Mill
    Last Post: 09-30-2009, 12:07 AM
  3. Replies: 5
    Last Post: 01-23-2005, 03:35 PM
  4. where to find links about integrating mini mills with robot
    By gv71 in forum RC Robotics and Autonomous Robots
    Last Post: 01-18-2005, 12:06 AM
