Originally Posted by
pkelecy
I would expect servo's to position more precisely, although the difference may be minor. However, they're also much more energy efficient. So for the same input power (which could be limited if used in, say, a home shop environment) you get more output power (i.e. can make faster feeds or deeper cuts). Conversely, it uses less power for the same work. So if you run the machine a lot, it could make a noticeable difference in your electric bill.
I guess it all depends on price premium Mikini charges, but definitely worth considering, I think.
