- Center cutting?
Center cutting?
I want to use a ballnose (or ballmill) end mill to mill a groove into a part for a tube. So far, we have avoided using the end mills because of the small line the ballnose end mills leave inside the groove in the center. I believe the end mills that we have are all center cutting. Will a non-center cutting ballnose end mill leave a nice smooth finish without any lines?
- Center cutting?
- You may not post replies
- You may not edit your posts
Forum Rules
