Results 1 to 4 of 4
Thread: Material suitable for shearing abrasive cloth
    Dec 2006
    Singapore
    Hi guys, I have a automated machine used for shearing abrasive cloth. The cloth is shear using a die cut. Currently the cutter is made of high speed steel of HRC 63. But the life span of the cutter is very short. I need to change the cutting tool twice everyday.
    I have tried with carbide material, the lifespan is only 2.5 time more than the high speed steel.
    Is there any suitable material for cutting abrasive cloth?
    Dec 2006
    Singapore
    anyone come across materials use for cutting abrasives cloth?
    Mar 2005
    What abrasive are you cutting? Whatever material you choose, your cutter is going to have to be substantially harder than abrasive which is a bugger if you actually plan on shearing the particles too. I think your ideal solution would be to cut the cloth backing and let the particles stick to whatever side of the cut they want to.
    Are the abrasive particles much smaller than the thread of the cloth backing? Is it possible to cut the cloth backing with the particles on the bottom side and not bottom out the die? I'm assuming you're doing something similar to steel rule die cutting (outline cutting onto a flat backing). If the abrasive particles are coarse, maybe you can stop the die cut before the cutting die bottoms out on the backing plate. Are you using a soft backing plate? Perhaps a softer backing plate would allow the grit to deflect into the plate instead of bearing overly hard on the cutting edges.
    Is laser or waterjet cutting an option?
    Dec 2006
    Singapore
    Quote Originally Posted by MadMax View Post
    Yeah, I am cutting the abrasives cloth from the back of the cloth. I have 2 cutters, the fixed and moving cutter. The moving cutter actually pushes the back of the cloth (which does not contains abrasives) to the edge of the fixed cutter.
    The fixed cutter wears out very fast.
    The abrasives grains can be quite tiny and may be thiner than the thread of the cloth.
    Both laser cut and waterjet is not suitable for my application.
    By using a softer moving cutter actually improved the situation?
    What is the general rule of HRC level be for cutters in order to last quite a substainial?
  1. Textile (cloth) cutting CNC
    By nikolatesla20 in forum General Material Machining Solutions
    Last Post: 11-09-2010, 12:34 PM
  2. CF cloth project
    By ninjay in forum Composites, Exotic Metals etc
    Last Post: 05-15-2009, 07:17 PM
  3. Suitable motor for abrasives cloth feeder
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 03-23-2009, 09:03 AM
  4. cutting die to cut abrasive cloth?
    By Syphonics in forum General Metal Working Machines
    Last Post: 11-21-2008, 10:15 AM
  5. rotary cloth cutting tool
    By gevannos in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 05-15-2003, 06:30 PM
