Results 1 to 4 of 4
Thread: 1-1/2 ball end insert cutter
    Feb 2008
    Is anyone looking to sell or know were I can get my hands on a 1.5 ball end mill insert cutter. I need ASAP.
    Nov 2007
    Although I'm not sure that they don't make one that big, the biggest one I,ve seen and used was 3/4. Do you have the option to achieve your contour by kellering, i.e., in steps?
    Nov 2007
    I spoke too soon. Seco Carboloy make one
    http://www.secotools.com/upload/nort...2%20218.20.pdf
    Registered aaron p's Avatar
    Oct 2007
    Ingersoll also makes one I believe and so does Sandvik probably. Check ebay for them. tons of tooling on ebay.
    "We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
  1. Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding & Toolgrinding Machines
    Last Post: 09-13-2010, 01:25 PM
  2. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 05:15 PM
  3. Looking for Insert.
    By Al_The_Man in forum General Metalwork Discussion
    Last Post: 08-02-2007, 11:27 AM
  4. Insert for 62 Hrc
    By M-man in forum General Metalwork Discussion
    Last Post: 02-13-2007, 04:09 PM
  5. INsert Molding
    By PC7 in forum Moldmaking
    Last Post: 04-15-2006, 07:56 AM
