Results 1 to 4 of 4
Thread: TOOLPOST GRINDER
    Mar 2008
    U.S.
    TOOLPOST GRINDER
    DOES ANY ONE HAVE PLANS TO BUILD A TOOLPOST GRINDER
    I am working on a small i c motor and need a toolpost grinder to grind the crank. not interested in buying one, just a hobby, but willing to make one.
    thanks!
    Mar 2003
    in a pinch or a onesie setup - many have used a dremel-type tool that is held in a hose clamp or a u-bolt hold-down fitting onto your compund. use whatever clamping arrangement necessary even up to cutting a special wood block to sit on the compound and hold the tool housing firmly.
    although its hard to get the dremel stone exactly perpendicular to the lathe axis- it isnt needed to be perfect to get the desired result.
    the grinding pressures are supposed to be very moderate so the tool pressure onthe mount should not be a problem factor. use coarse stones and watch for glazing, dress them often and do your setups and measurements carefully. even a coarse stone will gibe a failry fine finish on a rotating shaft and you can easily hone the shaft the last tenth or so with a handheld stone once its ground to size
    otherwise, you can use a sewing machine motor and their accompanying belt drives and parts, make a few speed reducing or increasing pulleys if needed and mount the stones directly on a drill rod axle or use an arbor-type tool ( think mill holder with a setscrew) to hold a mounted stone. take a small motor mounting bracket and mount the motor onto it and use the extra space to hold the secondary axle in a dual brass bushing or a skate bearing arrangement. simple setscrew collars to hold the shafts in place. easy to make a cone pulley for speed changes when using the round rubber drive belting or even the angular vee type.
    Jun 2005
    HI ,
    I made a bracket to hold my 4" angle grinder on the toolpost.
    Works great. I dress the wheels and can line up to any angle.
    wjf
    The More I Learn The Less I Seem To Know
    May 2006
    Dumore toolpost grinder
    I have a genuine one for serious use. 8,500 10,000 rpm
    Production quality true running
    Brian 619.200.7203
    Been doing this too long
  1. CHEAPY TOOLPOST GRINDER
    By smallblock in forum Shopmaster/Shoptask
    Last Post: 03-13-2008, 06:57 PM
  2. Rear toolpost operations?
    By zephyr9900 in forum Mach Lathe
    Last Post: 10-12-2007, 05:00 PM
  3. QC toolpost problems
    By daedalus in forum Mini Lathe
    Last Post: 09-23-2006, 05:43 PM
  4. QC toolpost
    By Cocotmm in forum Mini Lathe
    Last Post: 02-07-2006, 11:07 PM
  5. Quick change toolpost
    By Klox in forum General Metalwork Discussion
    Last Post: 01-10-2005, 01:38 PM
