Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > Metal Working Tooling
Metal Working Tooling Tooling specific to Metal Working
Old 03-02-2008, 08:19 PM
slaytonic is on a distinguished road
corner rounders
Hello, can anyone tell me how to program a corner rounder? i am trying to program a .0938 radius 115 minor diameter .250 shank corner rounder. i am using mastercam x but manual programming would be ok also. my zero is bottom of part and the edges i need to round are between .250 and .800 above that. i got the speeds and feed working its the depth of the cutter i am having trouble with. thanks tom
Last edited by slaytonic; 03-03-2008 at 09:08 PM. Reason: had wrong cutter size rad
Old 03-20-2008, 01:17 PM
bugzpulverizer's Avatar
bugzpulverizer is on a distinguished road
I would usually touch my corner rounding tool off z-zero on the flat above the radius. That way I just program it as an end mill with diameter equal to diameter of hub. Then program tool to top depth of corner you want to round. Just watch out for clearance when you have to rapid over the part. Mastercam will just program it to a Z-depth equal to your radius, if I'm not mistaken. We all know different brand corner rounders have different depths from tip to flat. So this takes care of that. Hope this helps.
Old 03-23-2008, 10:20 PM
great
I will try that out. it makes sense thank you.
Corner Rounding on TM1 JHamdan78 Haas Mills 11 08-14-2007 03:43 AM
corner rounding sundy58 FeatureCAM CAD/CAM 1 11-22-2006 08:54 PM
Corner Tunnels mikkojay Vectric 12 11-02-2006 12:11 PM
inside corner slowdown camtd Surfcam 1 01-21-2006 03:14 AM
corner rounding inthedark General Metal Working Machines 7 02-07-2004 06:30 PM
