Results 1 to 3 of 3
Thread: taper attachment
    Jan 2008
    taper attachment
    Hi gentlemen and ladies, im new here so i thought id say hi and pose a small question. I have a 12x36 atlas lathe 3996, i got a taper attachment or at least part of one. Since i have not seen one in use im not sure of how it connects and if i have all of it. Does anyone have a detailed picture of one and or a picture of the parts ?
    Aug 2005
    Here is a link to How to use a lathe. It has some decent info on the taper attachment setup and use.
    How to use a Lathe
    The drag on the assembly must be minimal. Cutting can only be done in one direction to prevent gouging as spring and backlash is bound to exist. I have found it neccesary to start my feed, then bring the cutter into the material and then back out before power feed is dropped out or a gouge will result. With a little practice, you can make it work, but it can be a real pain if the attachment is not bind free, compounded by flex and slop from the clamp or rod on light duty lathes.
    DC
    Attached Thumbnails Attached Thumbnails taper attachment-taper_attachment.jpg
    Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
    Jan 2008
    Very nice, so i have all the parts to the attachment, only thing i cant make out is where and how the thing mounts. Thanks a lot.
  1. NEEDED- taper attachment or 3 axis vise
    By klysons in forum General Metal Working Machines
    Last Post: 01-03-2010, 04:15 PM
  2. looking for taper attachment, manuals
    By klysons in forum General Metalwork Discussion
    Last Post: 01-02-2010, 11:46 PM
  3. 5ax attachment
    By sandiegocadcam in forum Open Source CNC Machine Designs
    Last Post: 03-12-2008, 09:36 AM
  4. Anyone knows what's this attachment and what's the use??
    By cbucner in forum General Metalwork Discussion
    Last Post: 04-03-2006, 11:04 PM
  5. Tapping attachment
    By phantomcow2 in forum Bridgeport and Hardinge Mills
    Last Post: 01-03-2006, 09:46 PM
