a good er collet should work
if you have DA holders you can get collets that have rubber in the slits to allow for thru spindle coolant ,you can probably get er's the same.
best performance and tool life will be gained by dialing in the drill dead nuts,carb drills don t like to be offset
LinkBack URL
About LinkBacks
