Results 1 to 3 of 3
Thread: Insert cutoff tooling cross-reference?
    Aug 2009
    I've been using Swarf products brand tooling for insert blade and inserts. Can't believe they are their own design without following ISO/ANSI standard but I can't figure out their numbering system for their inserts or blades to possibly shop elsewhere. What I need is a double ended blade .095? thick for .118-.125 insert. I have many inserts but just wrecked my last blade. Swarf blade ID is XLCFN 3202 M3.00 Inserts are LFMX 3M 8030 (the 8030 is grade)
    Any direction would be helpful. Thanks, Jack
    Mar 2008
    Why use such a little-known maker for cutoff tools? There's plenty of the well-know maker's stuff out there that would be so much easier to find from myriad sources.
    These days, cutoff tools are all propreitary inserts, blades and/or holders. About the only thin left that is interchangeable is the blade holder blocks. A 26mm or 32mm blade from one company fits into another company's block. With the inserts and blades, there's not much interchangeable. I do believe you've probably got a 32mm (1.250" - 1.260") tall blade with a 25mm (.984") height from bottom of blade to cutting edge.
    Some Kennametal will exchange with some Manchester as Kennametal owns both companies. Same for for Sandvik and Valenite (now Walter Valenite.) The Sandvik Coromant R/L/N 151.2 series interchanges with Valenite VSG series. The Coromant R/L/N 123 series swaps with Valenite VTG series stuff. Same pocket geometry in the blades and insert shapes, just different grades, coatings and chipbreakers for the inserts.
    If "Swarf" changes with any other company, I've never heard of it.
    Walter has some cutoff tools with a "XLDE" designation but the double-ended inserts for them are a GX16 or GX24 style. Like I said, it's all proprietary so get into a system with one of the more well-known brands to be sure you can get the stuff for a long time to come. There's no ISO or ANSI standard in grooving/cutoff since the v-bottomed/flat-topped "dogbones" of the 1960's into the 1980's, (Valenite VDB, for example) and they're not well-supported now because the geometry sucked.
    The "8030" grade you mention sounds like it could come from Ingersoll/Taegutec, so check into their system. Maybe they have blades for your inserts. I'd find one blade, exhaust the insert supply and get into a better-known brand.
    Geezuz...I just went "googling" that Swarf cutoff tool and there is NOTHING out there! Where the heck did you buy such a thing?
    Aug 2009
    Thanks for the insight. Swarf is sold through Quality Corp. out of Arlington, TX.
    It seems from what you say that no matter who one goes with, they are stuck with that manufacturer. I just wanted more possibility of getting a more competitive price. Looks like it's time to switch makers.
  1. Craftsman router collet cross reference?
    By johnmac in forum DIY CNC Router Table Machines
    Last Post: 12-12-2008, 04:08 PM
  2. cross reference servo drive help
    By vesteroid in forum General Metal Working Machines
    Last Post: 11-21-2007, 09:14 AM
  3. Retention Knob Cross Reference for 50 Taper?
    By pdoherty in forum Haas Mills
    Last Post: 12-13-2006, 11:54 PM
  4. diode cross reference
    By messar in forum General Electronics Discussion
    Last Post: 12-08-2006, 07:43 PM
  5. Shoptask Bearing Cross-reference?
    By Jasonixo in forum Shopmaster/Shoptask
    Last Post: 04-17-2006, 10:12 AM
