Results 1 to 2 of 2
Thread: milling hard rifle actions
    elc
    elc is offline
    Apr 2010
    trying to mill the top of 40x actions for scope rail and then rotate to 15 degrees to mill out left side to make dual loading port--problem these actions are very hard on surface the depth of hard varies from action to action--on the left cut it is hard on inside and outside with machinable core--i am using a tormach with 4th axis and made a mandrel to hold work--am wearing out carbide mills at a rapid rate and chipping mills even faster--when i try cutting the left side using the side of the mill with a lot of pressure and get through the hard surface the sprial grabs the work and pulls the mill adaptor from the r8 collet in the headstock and into my mandrel--am using koolmist and air--would a left spiral mill work putting pressure up?--carbide burr? or any suggestions
    Registered neilw20's Avatar
    Jun 2007
    Mount a small CBN wheel and grind it. Slightly slow, but really easy.
    On hard stuff don't run carbide mills too fast. Sometimes air instead of coolant is better, as the hot chips harden as you produce them.
    I have machined grooves in ball races using tipped tools intended for chilled cast iron. Really slow feed and speed here too.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. Need Help!- PC to Fanuc proper actions.
    By Schljuutene in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 08-10-2010, 01:47 AM
  2. Problem- Hard Milling CPM-15V
    By StuartTool13 in forum Metal Working Tooling
    Last Post: 07-04-2010, 03:29 AM
  3. hard milling d2
    By ihavenofish in forum General Metalwork Discussion
    Last Post: 09-11-2009, 03:15 PM
  4. hard milling on an nm-070
    By ihavenofish in forum Novakon Systems
    Last Post: 08-17-2009, 06:17 PM
  5. Milling a very hard material
    By arazelan17 in forum General Metalwork Discussion
    Last Post: 02-16-2006, 12:09 AM
