Results 1 to 5 of 5
Thread: TRICK R8 Tooling
    Oct 2006
    TRICK R8 Tooling
    I am wanting to hear from users of R8 spindle machines (manual or CNC) about any TRICK R8 tooling that increases their through-put, efficiency or simply makes their machining more enjoyable.
    I'll start with these:
    Jancy Engineering
    Annular Cutter Holders - Toolmex Corporation
    Tool Holders, Mill Holders, Collets: Collis Toolholder Iowa
    These are various types of toolholders for using annular cutters either with or without Through-Coolant, as well as Weldon shank cutters with Through-Coolant via an inducer collar...pretty trick stuff for an R8 spindle machine!
    Annular cutters are EXCELLENT for larger hole sizes and require less horsepower to run, not to mention the finish is equivalent to a bored/reamed hole in many cases.
    Registered HelicopterJohn's Avatar
    Dec 2005
    Seffner, Florida USA
    R8 Adapter
    Here is a picture of the #30 Quick change adapter that I use on both of my Bridgeports. Makes tool changes a breeze.
    Attached Thumbnails Attached Thumbnails TRICK R8 Tooling-30_quick_change_page_1569_msc.jpg   TRICK R8 Tooling-img_0286a.jpg
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://www.helicopterjohn.com/
    Oct 2006
    Also looking for all those must-haves and nice-to-have accessories...like bore mounted jig-grinder, spindle speeder, etc.
    Oct 2006
    Anybody? Surely in this community there are users who have some trick R8 tooling that they just can't work without!
    Sep 2006
    Hi I have a Tree boring and facing head with R8 shank that can bore a tapered hole...it can also bore a parallel hole and face flat or convex and concave under power too, but the main attribute for this head is it can bore tapered holes too under power feed when required.
    Ian.
    1. Need Help!- V23, Please show this old dog a trick or two
      By Waynno in forum BobCad-Cam
      Last Post: 05-10-2010, 10:27 AM
    2. hyperVIEW trick
      By single phase in forum Hypermill
      Last Post: 03-10-2008, 11:32 PM
    3. need a trick
      By KBW in forum General CAM Discussion
      Last Post: 05-28-2007, 04:42 AM
    4. Autcad UCS trick
      By wjbzone in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 02-24-2005, 10:20 AM
    5. Little known trick
      By Turbine in forum GibbsCAM
      Last Post: 07-28-2003, 11:37 AM
