Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Metal Finishing and Plating
Old 02-13-2010, 08:16 PM
ErnieD is on a distinguished road
Coloring brass
I want to engrave a plaque for a friend and I want to darken the brass prior to engraving. This will let the lettering show up quite well against the dark background. I would like to do this using readily available materials that I can purchase inexpessively and mix up at home.
Can anyone out there give me some suggestions?
Thanks,
Ernie
Old 02-14-2010, 09:09 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
Head down to the local Wal-Mart and look in the Sporting Goods section for Birchwood Casey's Brass Black. It's sort of like a cold bluing solution for brass. It will eventually rub off, so after the engraving you'll need to shoot some clear lacquer or Brass Brite coating on top of it to preserve the bluing.
Mark
Old 02-14-2010, 09:41 AM
Mark,
Thanks, I will try that today.
Ernie
Newbie- Weld Brass to Brass piratesover40 Welding, Brazing, Soldering, Sealing 3 03-03-2008 06:02 PM
painting & coloring via cnc? vaneeck1 Printing, Scanners, Vinyl cutting and Plotters 1 03-25-2006 12:33 PM
Brass...why? creative_mind General Metalwork Discussion 2 05-25-2004 12:27 AM
How can I cut Brass? cbcnc General Metalwork Discussion 3 01-13-2004 07:54 PM
Where to buy Brass? NeoMoses General Metalwork Discussion 3 10-05-2003 08:35 PM
