[QUOTE=Julian M;287299]Does anyone know how othen you need to replace the dilute sulphuric acid
in the anodising tank.How do you know when it needs replacing?
THanks for any help
Julian[/QUOT
Dear Julian,
This probably will not be much help unless you have access to a better chemist than me, but this document tells you how to analyse the chemical composition of your electrolyte...
http://www.metroplating.co.uk/pdf/DE...AN%2003-25.pdf
Annex A and B describe the tests.
I have no idea of the range that is acceptable for each component in the electrolyte.
Bring on the chemists!
Best wishes
Martin
LinkBack URL
About LinkBacks
