Results 1 to 3 of 3
Thread: Surface finish on journals
    Mar 2010
    U.S.
    This might be the wrong forum.
    I am trying to develop a technique to produce a very fine finish on both the stator and rotor of a very close tolerance journal bearing. I believe that I can develop a process on the rotor using a tool post grinder and polishing compounds but I am not sure how to approach the bore finish in the stator.
    Has anyone done this and can recommend a process?
    Rick Kernell
    Apr 2010
    take a look at roller burnishing tools. I've used cogsdill & elliot with much success. been awhile but if I remember correctly you bore (or ream) within a few "tenths" then run the burnisher. you can get .0002 size control and 2-8 microinch surface finish, besides a better bearing surface because of the work hardening.
    For OD work look at the cogsdill diamond burnishers. Finish turn a bit oversize then burnish to an 8 finish and .0003 tolerance on size. Did this on crankshaft journals very reliably on a line with a 23 second takt time (that included turning and burnishing).
    Mar 2010
    U.S.
    Surface finish
    Thank you for this information. I will look them up.
    Rick
  1. Surface Finish
    By pgf545 in forum PTC Pro/Manufacture
    Last Post: 01-24-2012, 10:03 AM
  2. Need Help!- Surface Finish
    By dlange in forum General Metalwork Discussion
    Last Post: 09-21-2010, 02:02 PM
  3. 64 RMS Surface Finish?
    By pzzamakr1980 in forum General Metalwork Discussion
    Last Post: 01-13-2009, 05:19 AM
  4. Surface finish
    By chakaloso in forum General Metal Working Machines
    Last Post: 06-12-2007, 09:54 PM
  5. 32 surface finish
    By mroy0404 in forum General Metalwork Discussion
    Last Post: 05-28-2006, 10:02 PM
