Metal Finishing / Plating
Page 1 of 5 1234 ... LastLast
Threads 1 to 20 of 98
Forum: Metal Finishing / Plating
Discuss Metal Finishing / Plating here!
  1. Need Help!- Contamination under black light on aluminum anodized
    Started by Miguel58rt‎, 11-14-2017 09:01 PM
    11-21-2017, 04:06 PM Go to last post
  2. Problem- Aluminum anodizing - what am I doing wrong?
    Started by J S Machine‎, 10-26-2017 12:16 AM
    anodize, dye, hanging, parts, wire
    10-26-2017, 12:16 AM Go to last post
    10-23-2017, 09:17 AM Go to last post
  3. Question German language surface treatement callout?
    Started by beezerlm‎, 02-22-2017 11:27 AM
    callout, cmt, german, hrc, tmp
    10-07-2017, 04:48 PM Go to last post
  4. Need Help!- Anodizing
    Started by Bekmurod‎, 07-05-2017 10:57 AM
    anodizing, microns, reach, supplier, thickness
    07-11-2017, 04:28 PM Go to last post
  5. Anodizing quality issue
    Started by professorquack‎, 12-16-2016 08:08 PM
    12-16-2016, 08:47 PM Go to last post
  6. Mirror finish steel and aluminum parts vibratory bowl?
    Started by Toggle‎, 10-02-2008 09:41 PM
    mos, next, not, then
    11-07-2016, 10:14 AM Go to last post
  7. Need Help!- What anodizing method for matte finish?
    Started by Luis Van Damme‎, 09-02-2011 07:03 PM
    11-06-2016, 04:29 PM Go to last post
  8. conductive non metal material for plating?
    Started by manakawari‎, 09-08-2016 07:49 PM
    conductive, copper, material, plating, resin
    09-08-2016, 09:32 PM Go to last post
  9. Safe&cheap electroplating
    Started by kook‎, 07-06-2016 02:14 AM
    electroplating, home, plate, safe&cheap, stumbled
    07-17-2016, 11:10 PM Go to last post
  10. small batch heat treating
    Started by brian257‎, 06-06-2016 03:31 PM
    forum, price, small, steel, time
    06-06-2016, 03:31 PM Go to last post
  11. Aluminum 7075 surface finishing.
    Started by jsclark‎, 10-03-2014 12:01 AM
    almost, aluminum, behind, brass, brushes, buying, chuck, cnc, cnc machine, customer, facing, finish, finishing, holder, its, long, machine, parts, smooth, stainless, stainless steel, steel, surface, time, type, wire
    11-01-2015, 09:28 PM Go to last post
  12. Cool Problem- Copper plating Fiberglass
    Started by jlnading‎, 09-07-2015 06:36 PM
    copper, copper plating fiberglass, fiberglass, process, shared
    09-07-2015, 11:42 PM Go to last post
  13. Metal Calculator Android Program
    Started by mtnyvz‎, 09-01-2015 09:00 AM
    09-01-2015, 09:00 AM Go to last post
  14. Sanding Aluminum - with the grain?
    Started by tikka308‎, 03-04-2008 10:42 PM
    against the grain
    08-30-2015, 07:42 PM Go to last post
  15. Need Help!- Anodizing and brass..
    Started by lew90nicis‎, 04-13-2015 11:55 AM
    anodize, anodizing, brass, bushes, part
    04-13-2015, 12:29 PM Go to last post
  16. Need Help!- Nitriding general information/discution
    Started by ckielcave‎, 09-20-2014 07:30 PM
    ..., cavity, cnc, cnc., component, deal, finish, general, injection, mark, method, mirror, mold, mos, nitriding, open, part, product, star, stone, tool, transfer, treatment, work
    09-20-2014, 07:30 PM Go to last post
  17. Need Help!- Looking to get a Coke machine piece chromed
    Started by 34ford‎, 06-25-2014 06:53 PM
    09-06-2014, 09:47 AM Go to last post
    07-03-2014, 01:38 AM Go to last post
  18. Want rust finish on forging
    Started by Ted383‎, 02-01-2013 11:42 AM
    06-19-2014, 03:53 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
