| Mentors & Apprentice Locator Looking for mentors and/or for apprentices in your own locality please post your info. Do not post any personal info address, phone numbers etc. |
I need help with generating accurate cutting times for AlphaCAM & MultiCAM 5000, I was wondering whether anyone could point me in the right direction, regards to ; Establishing accurate cutting times using AlphaCAM & MultiCAM 5000 Fairly new to this, but I am unable to generate a cutting time, per job basis. I've managed a work-around, by selecting another machine type, Alpha STD, 3 Axis router. This is from within AlphaCAM. Can anyone please suggest a better approach. Many thanks Rico |
| HI Rico, to get times for your jobs in alphacam, goto file and click setup sheet, this will out put a drawing and list of all the operations on the current job, along with a time for each operation. this option is only selectable when you have a job open which has toolpaths or drillings on it. as long as your tool feeds are set correctly in the tooling files then the times are usually quite acurately. alternataivly there is a line you can input into your post, when you out put the job the time to run the panel will appear at the top of the program. john |
| Open up your Post Processor in Alpha Edit and page down to line... $540 Suppress Operations List, Start and Comments in NC code (1 = Yes, 0 = No) Set the line directly under this to 0 and save the Post. All comments, tools and cutting times will now appear in green text at the top of your NC programs. Last edited by FrankCNC; 08-14-2010 at 04:28 AM. |
| Hi Mike, Have as yet not used a Touch Probe, the companies I've worked for could never justify the cost. I dare say that whatever probe you get should come with its own probing Macro's to suit your controller that should make using the probe fairly easy. Controllers like the Heidenhain come equipped with probing Macro's and reading the manuals it looks fairly simple. Regards, Frank. |
| Tags |
| alphacam, multicam |
| AlphaCAM Post Needed (Licom) | NardisAmps | Screen Layouts, Post Processors & Misc | 5 | 09-15-2011 03:42 PM |
| AlphaCam Post | bado | Post Processor Files | 1 | 07-18-2011 02:55 AM |
| alphacam post haas tl1 ? | niel | Haas Mills | 1 | 08-14-2008 07:53 AM |
| Alphacam post for DMG iTNC 530 | roman6791 | Post Processor Files | 2 | 12-11-2007 03:14 PM |
| Alphacam Post | loupy | Post Processor Files | 2 | 07-21-2007 07:34 PM |
